Is BFD supported on the 7206-VXR platform?
Answered Question
Nov 27th, 2009
I've got a 7206-VXR with an NPE-G1 and IOS 12.4(22)T connected to a 3845 IOS 12.4.(15)T and am wanting to
configure BFD (bidirectional forwarding detection) between the routers.  I'm able to configure the
correct bfd commands under the 'router eigrp 1' using CLI, but there are no 'sh bdf xxx' show commands on
the 7206 router.
On the 7206 'sh ip eigrp in detail' shows that bdf in enable on the correct interface, but there are no
other show bdf commands.
ENG-7206-QMOE#sh ip eigrp interfaces detail
IP-EIGRP interfaces for process 1
                        Xmit Queue   Mean   Pacing Time   Multicast    Pending
Interface        Peers  Un/Reliable  SRTT   Un/Reliable   Flow Timer   Routes
Gi0/1.10           1        0/0         1       0/2           50           0
  Hello interval is 5 sec
  Next xmit serial <none>
  Un/reliable mcasts: 0/338172  Un/reliable ucasts: 224946/977
  Mcast exceptions: 6  CR packets: 6  ACKs suppressed: 13
  Retransmissions sent: 82  Out-of-sequence rcvd: 5
  Authentication mode is not set
  BFD is enabled
  Use multicast
ENG-7206-QMOE#sh bdf ?
% Unrecognized command
The 3845 router has BDF show commands:
VoIP-MDF-3845#sh bfd ?
  neighbors  BFD neighbors
Does the 7206 REALLY support BDF and if so are the show commands different?
Correct Answer by Reza Sharifi about 7 years 1 month ago
I did a search using the feature navigator and did not see EIGRP support for BFD on 7200s
Reza
Overall Rating: 5 (1 ratings)
Reza Sharifi Fri, 11/27/2009 - 10:56
You are typing "sh bdf" not "sh bfd"
use sh bfd?
Reza
jkeeffe Fri, 11/27/2009 - 11:27
I mis-typed that one, but the problem is still the same:
ENG-7206-QMOE#sh bfd
% Invalid input detected at '^' marker.
ENG-7206-QMOE#sh ?
  aaa                       Show AAA values
  aal2                      Show commands for AAL2
  access-expression         List access expression
  access-lists              List access lists
  accounting                Accounting data for active sessions
  adjacency                 Adjacent nodes
  aliases                   Display alias commands
  alignment                 Show alignment information
  aps                       APS information
  archive                   Archive of the running configuration information
  arp                       ARP table
  async                     Information on terminal lines used as router interfaces
  auto                      Show Automation Template
  backhaul-session-manager  Backhaul Session Manager information
  backup                    Backup status
  beep                      Show BEEP information
  bootflash:                display information about bootflash: file system
  bootvar                   Boot and related environment variable
  bridge                    Bridge Forwarding/Filterin
  buffers                   Buffer pool statistics
  c7200                     Show c7200 information
Correct Answer
Reza Sharifi Fri, 11/27/2009 - 12:53
Reza
jkeeffe Fri, 11/27/2009 - 13:06
You seem to be correct.  I did a search on feature navigator and it seems that it is not supported
on the 3845 router either - even though it took the commands.
