Hold doesn't work with calls via Gatekeepr
Nov 27th, 2009
I have a CME and CM via a gatekeeper.
Both can call each other via gatekeepr or PSTN.
If PSTN call was initiated first, I can still make another call via GK while put PSTN call on-hold.
But, if call via GK was established first, can't put the call on hold to mak/answer new call.
This only happen with phones on CM.
Any idea?
Brandon Buffin Mon, 11/30/2009 - 06:42
In CUCM admin, on the trunk to the gatekeeper, check "Media Termination Point required" and make sure there is an MTP in a Media Resource Group available to this trunk.
Hope this helps.
Brandon
smallrain_2 Mon, 11/30/2009 - 13:13
Hi Brandon,
Box was checked because the instruction I used suggested as well.
Just out of curiosity, I did unchecked and now it works fine.
Not sure what is going on.
I have CUCM 7 and CME 7.
Related Content
