Restore LMS 3.1 to 3.2
Answered Question
Nov 27th, 2009
Evening,
I am hoping to upgrade my LMS from 3.1 to 3.2 very soon. I have created a backup using NMSROOT/bin/perl backup.pl, and that has completed successfully (took a few tries, but it worked).
With this backup that I now have, can I restore it once I install 3.2 (I will be doing a clean install, not an upgrade)
Correct Answer by Joe Clarke about 7 years 1 month ago
Yes.  And you should reboot before starting the 3.2 installation.
Overall Rating: 5 (2 ratings)
Mario Elia Fri, 11/27/2009 - 15:08
Thank you jclarke,
Your answer is exactly what I was looking for.
Thanks again.
Mario Elia Fri, 11/27/2009 - 15:13
One more quick question;
Once the un-installation of 3.1 is complete, there is still a CSCOpx folder in my Program Files (Windows 2003).
Should/Can I delete that before I install 3.2?
Correct Answer
Joe Clarke Fri, 11/27/2009 - 15:18
Related Content
