CCX version 5.0.1 compatility with CUCM 7.1
Answered Question
Nov 27th, 2009
Hi, does any know whether ccx 5.0.1 will work ok with CUCM 7.1
and if so is it supported  by Cisco.
Regards Dominic
Correct Answer by Chris Deren about 7 years 1 month ago
It is not supported, reference this doc for supported deployments:
http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/crs/express_compatibility/matrix/crscomtx.pdf
however it will probably work (I would not recommed running it though) as during a recent upgrade of CM to version 7.1.3 it continued to work with UCCX 5.0 before I upgraded it to version 7.0.1 sr4 as well.
HTH, please rate all posts!
Chris
Overall Rating: 5 (1 ratings)
Correct Answer
Chris Deren Sun, 11/29/2009 - 09:03
Chris
