CME 8.0 (15.0(1)XA) vs SIP trunk DTMF issues
Nov 28th, 2009
I've upgraded my 2821 to 15.0(1)XA to try out CME 8.0. I have a SIP trunk coming in from an ITSP and everything works fine using 12.4(22)YB4. When I upgrade to 15.0(1)XA, DTMF stops working on 90% of my calls (I am forcing RTP-NTE). I have not changed the config between 12.4(22)YB4 and 15.0(1)XA at all.
Tech support tells me that they are receiving RFC2833 packets but they're too short - according to them, the 3 first packets have 0ms duration, the middle packet has 400ms duration and the last 3 have 800ms. They have suggested that I send inband DTMF instead, but I am not really inclined to do that because it worked before. I've tried specifying the payload setting (101) and other settings on my dial-peers to no avail. I have been forced to return to CME 7.1 because of this.
All my phones are SCCP and this problem is reproduced on a broad range of phones including analog phones off a EVM board (SCCP-controlled).
Any ideas?
Nicholas Matthews Sat, 11/28/2009 - 13:34
  • Red, 2250 points or more
You may want to try this command:
voice service voip
dtmf-interworking rtp-nte
It changes the interarrival properties of the 2833 packets, and we see it particularly with Verizon trunks, though it has been useful in other scenarios as well.
-nick
J. S. Black Sat, 12/12/2009 - 19:50
Hi Nick,
I just tested dtmf-interworking with 15.0(1)XA, no change.
Any debugs I should be looking at?
paolo bevilacqua Sat, 11/28/2009 - 23:47
  • Hall of Fame,
    Founding Member
The rigth approach would be to have cisco fix what is broken, unfortunately the burden of proof is on you and it can take a lot of time and effort.
The alternative is to go back to working IOS and upgrade when new software is less buggy.
Nicholas Matthews Mon, 12/14/2009 - 06:33
I would start by getting a packet capture.  Then, you can look if you receive the packets.  Something like 'rtp.payload_type == 101' may be a good wireshark filter.
For debugs, you're looking at using 'debug ccsip messages' and 'debug voip rtp session named'.
You're probably best off opening a tac case with this information because it sounds like something that isn't as straightforward.  Double check your dial peers - maybe they were read in differently with the new IOS and haven't been applied the same in the two versions.
-nick
