ip phone timezone can no update
Nov 28th, 2009
I installed a CUCM-BE 7.13 in place with 7941s throughout.
My time on the phone is not correct, although in my Time/Date area on CUCM, it specifies the correct timezone and time on the server appears to be correct.NTP server sync well.
I checked date/time group configuration. device pool configuration.
, try make a new Dev Pool with a new Date/Time group and set difference timezone.
I can change the phone's date/time format, but not the timezone.
no matter what timezone I changed. the phone's time never change.
Can anyone tell me how to get the timezone correct on these phones?
Any Suggestions?
Best Regards,
Steve
vivkalra Sat, 11/28/2009 - 11:15
Hi ,
What is the exact call manager version you have installed
Because the call manager was hitting a DST bug CSCsy25150
Upgrade the call manager to the latest patch to get this fixed
steve7388 Sat, 11/28/2009 - 13:52
Hi Vivek Kalra:
CUCM 7.1.(3.10000)
Because the new 7941 phone register to CUCM has the TFTP "auth fail" problem.
I downgraded the Phone Firmware for CUCM 7.1(3) to 8.5(2), I will upgrade the CUCM to latest patch 7.13a after all the
phone installed.
I think my problem is not the DST bug. I have try to change the Date/Time group with many different timezone to test.
(GMT -1 ,-3 , -7 ,+3.....). The time show at the phone never change. The phone always show the time of GMT 0.
seems the timezone setting do not reach the phone.
steve7388 Mon, 11/30/2009 - 19:13
We check the SEPxxxx.cnf.xml file , no the timezone information in the configure file:
D-M-YA
sachin.mahangade Mon, 01/11/2010 - 03:17
Did you resolved this after the patch upgrade???
Was there any other solution for this?
steve7388 Mon, 01/11/2010 - 07:44
CUCM V7.13
Can not select the timezon endwith "*"
After changed the timezone , problem solved
sachin.mahangade Mon, 01/11/2010 - 07:55
we tried to use either of the Time Zone.. with * and without * .. but still on the phones (7945G) its not updating....
any ideas???
htluo Thu, 01/21/2010 - 09:19
  • Red, 2250 points or more
Dude, he's not hitting that bug.  Didn't you see that he tried the timezone with "*"?  I would recommend him restart TFTP.  It looks like the phone didn't get the updated config file.
Michael
http://htluo.blogspot.com
pratik.rb Thu, 01/21/2010 - 09:34
I had the exact same issue with CM 7.1.3a as well as 7.1.3b today. The 7911, 7942 and 7965 on my network would show only GMT time whereas 7925 & CIPC was fine.
After upgrading to 7.1.3b I changed to a timezone with * and it reset from Date/time group page itself and immediately the phones started working.
Sachin, are you on 7.1.3a or 7.1.3b perhaps this workaround works only with the latter??
sachin.mahangade Fri, 01/22/2010 - 00:48
Sorry guys for not updating... yes... we upgraded it to 7.1(3b) and then selcted the timezone with * ... and not its working fine for the phones...  this may be the workaround for timezone issue...
