VG224 with SCCP Question?.
Answered Question
Nov 28th, 2009
I have a CCM 6.1.4 with two VG224 GW  using SCCP Protocol.  All features are working fine.
But I  got a question, it is possible to know what extension  does the  analog phone has configured on it , dialing a number or  pressing a key, my analog phone doesn´t have display screen.   In my  PBX i was able to know this.
Thanks in Advance.
Correct Answer by Jaime Valencia about 7 years 6 months ago
Unfortunately there is no such feature, the only way is via CCMadmin
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
Overall Rating: 5 (1 ratings)
robert.bernal Sat, 11/28/2009 - 22:01
Thanks for reply,   well  this really didn´t help me,  anyway thanks.
I fix  my problem  creating a  IPCCX  Script  and i achieve  it.
Best Regards.
Robert.
