voip call disconnect when remote end picking the call
Nov 29th, 2009
hai all
my connection is like EPBX ------ R1 ______________ R2 ------EPBX
Connection
epbx ro R1/R2(2811) is an t1/e1
R1 to R2  a leased line
Problem: when we are trying to call from phone connected @ PBX A to PBX B get ring , when we picks the phone the call goes disconnected ....
please help me to resolve this issue.... please find the router configuration bleow and debug isdn as attached
Router Configuration
sh runn
hostname XXX
card type e1 0 0
card type e1 0 1
no aaa new-model
no network-clock-participate wic 0
network-clock-participate wic 1
network-clock-select 1 E1 0/1/0
ip source-route
no ip domain lookup
no ipv6 cef
isdn switch-type primary-qsig
voice service pots
supplementary-service qsig call-forward
voice service voip
qsig decode
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service h450.2
no supplementary-service h450.3
voice register global
voice-card 0
crypto pki trustpoint TP-self-signed-4028325014
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-4028325014
revocation-check none
rsakeypair TP-self-signed-4028325014
crypto isakmp policy 1
encr 3des
hash md5
authentication pre-share
group 2
crypto isakmp key ramajeyavpn address 10.10.10.2
crypto ipsec security-association lifetime seconds 86400
crypto ipsec transform-set ramajeya esp-3des esp-md5-hmac
crypto map ramajeyamap 10 ipsec-isakmp
set peer 10.10.10.2
set transform-set ramajeya
match address VPNACL
controller E1 0/0/0
channel-group 0 timeslots 1-16
controller E1 0/1/0
pri-group timeslots 1-31
interface FastEthernet0/0
description $ES_LAN$
ip address 192.168.2.1 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
ip address 10.1.1.2 255.255.255.0
duplex auto
speed auto
ids-service-module monitoring inline access-list 101
interface Serial0/0/0:0
ip address 10.10.10.1 255.255.255.0
encapsulation ppp
interface Serial0/1/0:15
no ip address
encapsulation hdlc
isdn overlap-receiving
isdn incoming-voice voice
isdn contiguous-bchan
no cdp enable
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 10.1.1.1
ip route 192.168.0.0 255.255.255.0 10.10.10.2
ip route 192.168.2.254 255.255.255.255 IDS-Sensor0/1
ip http server
ip http secure-server
ip access-list extended VPNACL
permit ip 192.168.2.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 101 permit tcp any eq www any
voice-port 0/1/0:15
ccm-manager fax protocol cisco
mgcp fax t38 ecm
dial-peer voice 100 voip
destination-pattern 1..
session target ipv4:10.10.10.2
supplementary-service pass-through
dial-peer voice 500 pots
destination-pattern 5..
direct-inward-dial
port 0/1/0:15
forward-digits all
dial-peer voice 200 voip
destination-pattern 2..
dial-peer voice 300 voip
destination-pattern 3..
dial-peer voice 400 voip
destination-pattern 4..
--More--         !
line con 0
line aux 0
password cisco
login
line 258
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
speed 115200
line vty 0 4
password cisco
login
scheduler allocate 20000 1000
end
Marwan ALshawi Sun, 12/27/2009 - 00:06
i think al most this is codec issue
can you please try the follwoing
add an additional incoming dial peer in each of your routers with the following settings
dial-peer voice 90 voip
codec g711 ( use ulaw or alaw based on what is the codec used in ur PBX)
incoming called number 1..
as the voip dial peer by default uses the codec as g729
when you make the above dial-peer as the default incoming dial peer and enforce the codec will make sure no Xcoding required
and then try to make calls
good luck
if helpful Rate
