static nat identity and static map
Nov 29th, 2009
Hi all,
i've got a doubt....
i have to do nat identity for a /25 but 2 addresses of that /25 must be mapped:
ex
static (inside,outside) udp 1.1.1.1 53 2.2.2.1 53 netmask 255.255.255.255
static (inside,outside) udp 1.1.1.2 53 2.2.2.2 53 netmask 255.255.255.255
static (inside,outside) 1.1.1.0 1.1.1.0 netmask 255.255.255.0
i think will work even if i've got a WARNING message like
mapped-address conflict
if i perform a show xlate i can see before first 2 entries and then third one.
do you think i'll have any issue? may you know better or more elegant way to do this?
tnx
Dani
Overall Rating: 3.5 (2 ratings)
jan.nielsen Sun, 11/29/2009 - 12:21
  • Gold, 750 points or more
Should be ok, since the first two statics are more specific than the broad network static. If it doesn't work, you could try a policy static nat instead for the two ips.
access-list hosta permit ip host 2.2.2.1 any
access-list hostb permit ip host 2.2.2.2 any
static (inside,outside) 1.1.1.1 access-list hosta
static (inside,outside) 1.1.1.2 access-list hostb
danilodicesare Sun, 11/29/2009 - 12:39
tnx Jan,
maybe i was wrong before 'cause i wanna mean:
static (inside,outside) udp 2.2.2.1 53 1.1.1.1 53 netmask 255.255.255.255
static (inside,outside) udp 2.2.2.2 53 1.1.1.2 53 netmask 255.255.255.255
of course your answer is the same ::)
access-list hosta permit ip host 1.1.1.1 any
access-list hostb permit ip host 1.1.1.2 any
static (inside,outside) 2.2.2.1 access-list hosta
static (inside,outside) 2.2.2.2 access-list hostb
but other question is....how can add those entries later.
so i've already got a command like
and i have to add more specific...do i need to do 'no static (inside,outside) 1.1.1.0 1.1.1.0 netmask 255.255.255.0', add more specific entry and then add again less specific entry?
maybe there is a tricky NAT entry that i can add without removing temporarly other one.
tnx a lot
Dani
danilodicesare Sun, 11/29/2009 - 23:33
hi,
must be the right way....
so if i need inside to outside untranslated and outside to inside untranslated + some static mapping il'll do:
PIX1# show running-config nat
nat (inside) 0 access-list nat_exemption      --> i wanna inside host to communicate untranslated to external host
nat (outside) 0 access-list nat_exemption   --> i wanna outside world to communicate untranslated to internal host
PIX1# show running-config static
static (inside,outside) 7.7.7.7 2.2.2.1 netmask 255.255.255.255 --> i wanna map real ip 2.2.2.1 with 7.7.7.7
static (inside,outside) 7.7.7.8 2.2.2.4 netmask 255.255.255.255 --> i wanna map real ip 2.2.2.4 with 7.7.7.8
PIX1# show running-config access-list
access-list all extended permit ip any any
access-list nat_exemption extended deny ip host 2.2.2.4 any
access-list nat_exemption extended deny ip host 2.2.2.1 any
access-list nat_exemption extended permit ip 2.2.2.0 255.255.255.128 any
i think is the right solution right?
tnx
Dani
Kureli Sankar Mon, 11/30/2009 - 06:26
  • Cisco Employee,
Dani,
We don't translate the source from low to high so, there is no need for nat (outside) 0 access-list nat_exemption. Also, nat 0 with an acl applied on the inside will allow traffic to be initiated from the outside. It is bi-directional.
Yes, this is the best way.  The acl looks correct.
Good luck.
-KS
