Enable outgoing phone logging?
Nov 29th, 2009
I don't seem to be able to find this easily, must be blind :) Is there a way to log all out going calls? Is it done automatically? If so, how can I make it so reports are sent at certain intervals?
Overall Rating: 5 (1 ratings)
Steven DiStefano Sun, 11/29/2009 - 13:39
I think you are talking about call accounting or CDR (Call Detail records)...maybe?
If so, the key word would be accounting, instead of logging.....
Third party Application avenue:
https://supportforums.cisco.com/docs/DOC-15347
(Verasmart &  ISI)
Freebie using WINRadius ( with Disclaimer ):
https://supportforums.cisco.com/docs/DOC-9670
A Few other methods using FTP Server or Syslog server:
https://supportforums.cisco.com/docs/DOC-9758
Steve
