key pair and the cert on the ACE
Nov 29th, 2009
We're in the process of generating a cert and the Key Pair on the ACE. We have successfully generated the Key Pair in the form of the ubdkey.pem. However, generating the Cert Signing Request requires the public key. How do we "separate" the public key from the Key Pair since only one Key Pair file (ubdkey.pem) got generated?
thanks..
Syed Iftekhar Ahmed Sun, 11/29/2009 - 16:46
When you generate a keypair it includes  both public & private key.
Use the keypair name  created earlier with the CSR generation command.
For example if you generate keypair named ubdkey.pem using the following command
crypto generate key 2048 ubdkey.pem
then use the same keypair in CSR generation command
 crypto generate csr   ubdkey.pem
Syed Iftekhar Ahmed
Related Content
