How to configure scheduler backup in FWSM
Nov 29th, 2009
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Hi All,
Is there any method to configure scheduler backup in FWSM.
Thanks & Regards
Ganesh.H
Panos Kampanakis Mon, 11/30/2009 - 15:04
  • Cisco Employee,
Also you can write an expect or tcl script that can do it for you.
Or you can write a vb script to do it with SecurteCRT automatically.
Or you can use Cisco RME platforma to do the updates automtically.
I hope it helps.
PK
Ganesh Hariharan Mon, 11/30/2009 - 22:37
If you have sample script available with you kindly share with me if possible !!
Ganesh.H
Ganesh Hariharan Mon, 11/30/2009 - 22:36
Let me try but i was actually in impression of some configuration in Firewall,Like we used to do in cisco router "Kron policy" configuration.
Ganesh.H
Panos Kampanakis Mon, 11/30/2009 - 22:47
  • Cisco Employee,
Unfortunately the FWSM does not have something like "kron policy" of IOS.
here is a script snippet
Here you ssh and then
expect {
     "Password:" {
     send "$vtypassword\r" }
     "Username:" {
     send "$username\r"
     exec sleep 1
     expect "Password:"
PK
