SPA500S - Adding speed dial number
gondange1
I would like to add speed dial numbers (external numbers) to the SPA500S on a SPA525G with UC520.
There is no possibility to do it in CCA 2.2 (I am running 8.0 system). I can just add monitor internal lines.
Is there any way to do it with CLI ?
Stephane
Steven Smith
Level 7
Level 7
Yes, you can do it with CLI.  You add to it the same way that you add to 7914, 7915, or 7916.  You just start configuring the extra buttons via CLI.
