mgetty errors on ucm cluster
David Wagner
i experience lots of mgetty errors in RTMT/Syslog Viewer (on all nodes).
Every hour, i can see the following error messages:
: failed dev=ttyS0, pid=XXXXX, login time out
: can't get user id for 'uucp': Success
: can't get group 'uucp': Success
So, what kind of problem do i have? Can anyone help me?
Jaime Valencia
Without knowing the CUCM version i'd suggest to look at this bug
CSCso55836
RTMT syslog messages failed dev=ttyS0 login time out
It appears it's just cosmetic as there really is no service affection, no WA right now.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
ok, thanks.
How long does it takes until the bug content will be available to me?
Sorry, i do not handle that information.
You may contact your AM or your SE so they can provide you further information on the bug
java
java
