C3560-G switch RPS power checking
Nov 30th, 2009
I have a switch that is plugged to two power sources:
1- The normal AC power
2- Redundant DC power supply (RPS)
I was checking in the " show environment" output the status of the 2  power sources, and got the below output,
My concern is about the DC Power, is it Normal like this?
Best regards,
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}
Core-SW#sh env all
FAN is OK
TEMPERATURE is OK
Temperature Value: 39 Degree Celsius
Temperature State: GREEN
Yellow Threshold : 55 Degree Celsius
Red Threshold    : 65 Degree Celsius
SW  PID                 Serial#     Status           Sys Pwr  PoE Pwr  Watts
1  Built-in                                         Good
SW  Status          RPS Name          RPS Serial#  RPS Port#
1   Active          <>
Core-SW#
Core-SW#
Collin Clark Mon, 11/30/2009 - 06:30
Yes this is normal. You can only get control features and advanced info with the 3750 series and above with stackables.
