Bandwidth Monitoring
Nov 30th, 2009
How to check which user is drawing how much bandwidth in real time?
Overall Rating: 0 (1 ratings)
Farhan Javed Tue, 11/01/2011 - 05:36
Hi Anupam,
You can use netflow to identify the per host bandwidth consumed on your link.
Regds,
Faiz
Farhan Javed Mon, 01/30/2012 - 07:58
Thanks Anupam,
is there any way instead of using the third party tool like netflow etc.
Regds,
Faiz
Don Jacob Mon, 02/06/2012 - 02:45
Hi Faiz,
For user level visibility you need NetFlow. If you do not want to opt for a 3rd party NetFlow tool and still see the results on the top users (IP Address), enable NetFlow on the interfaces and use the "IP TOP TALKERS" option if your router supports it.
After enabling NetFlow on the interfaces, for IP TOP TALKERS, config as below.
ip flow-top-talkers
top [number]                   Number of top talkers to be shown. Max is 200.
sort by [bytes | packets]   Sort based on volume or packets
cache-timeout [milliseconds]  How long top talkers info should be stored. Max is 3,600,000 milliseconds (1 hour).
Read more at:
http://www.cisco.com/en/US/docs/ios/netflow/configuration/guide/cfg_nflow_top_talk.pdf
Don Thomas Jacob
www.netflowanalyzer.com
NOTE: Please rate posts and close questions if your query has been answered
