UCCX - Music on Hold when not queued?
Answered Question
Nov 30th, 2009
Hello all,
I have a script that uses the "upload prompt" step. Some of the prompts it uploads are large and take a bit of time. Is it possible to play a wav whilst this transfer is going on?
Correct Answer by Jonathan Schulenberg about 7 years 2 months ago
I would suggest not putting "Music on Hold" in your thread subject then.
The answer is no unless you're real good with Java. You could create a seperate MoH stream on UCM, create a seperate set of CTI Ports for this application, and set these ports to that other stream; however, that may not be desirable depending on your environment. It certainly isn't very scalable.
Overall Rating: 5 (1 ratings)
Jonathan Schulenberg Mon, 11/30/2009 - 09:07
Sure. Put the caller on hold before you reach the Upload Prompt step.
Recording
--Successful
----Hold
----Upload Prompt
----Unhold
csg-admin Mon, 11/30/2009 - 10:24
Thankyou but the wav file I want to play is not the MOH file associated with the CTI ports, in otherwords when the caller goes on hold whilst uploading, I want to play a file from the prompts repository.
Is this possible?
Correct Answer
Jonathan Schulenberg Mon, 11/30/2009 - 10:31
