Call ID SPA9X2
Nov 30th, 2009
HI,
I'm using the phones SPA9X2 with Asterisk PBX and when a user A make the first call to User B only the called number of user B is displayed on the screen of the user A that make the call.
Why the phones are  not taken the caller id from asterisk? How can I fix this problem??
Thanks.
marck_renton Mon, 11/30/2009 - 10:29
the phones already have the latest firmware. i made changes in the value of caller id header but nothings happens.
icastrov Mon, 11/30/2009 - 10:31
Dear Sir,
can you please send me the trace on where we can see the SIP INVITE message that is getting the phone? The SPA9x2 configuration will also help...
Thanks!
-nacho
marck_renton Mon, 11/30/2009 - 10:53
SIP trace the call from extension 5002 to extension 3608. on the screen of extension 5002 I only view the number 3608, not the name of the user..
icastrov Tue, 12/01/2009 - 06:01
OK... problem seems to be with the To field in the 180 Ringing message, that's the one the phone will show in the display:
From your trace:
To: [email protected]>;tag=as7e178948
As you can see above, only the uri_user (3608) is being shown there... You'd need to change that in your Asterisk PBX in order to also include the uri user in that field.
Thanks!
-nacho
Related Content
