VPNHaus_SF_2 Wed, 01/27/2010 - 12:56
NCPs client is secure and easy to import .PCF files
Here is the data sheet for more information: http://www.ncp-e.com/fileadmin/pdf/datenblaetter/NCP_DS_Entry_Client_Win32_64.pdf
Good Luck!
- VPN Haus
http://vpnhaus.ncp-e.com/
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman","serif";}
Nelson Rodrigues Wed, 01/27/2010 - 21:02
  • Cisco Employee,
Yes, expect a 64bit IPSec client some time this year!!!!  BTW:Any other IPSec client that is not Cisco, is not be supported if you run into issues connecting to Cisco headend devices (ie. ASAs, IOS,etc)
VPNHaus_SF_2 Fri, 01/29/2010 - 06:54
Hi Nitin,
Not sure if you need a VPN client immediately...?  If you do, check out NCP Secure Entry Client- it's universal with devices and very easy to configure.
Check out our blog, we write more on this: http://vpnhaus.ncp-e.com/
Mike Wise Fri, 01/29/2010 - 08:14
If I remember correctly NCP cost money whereas Shrewsoft is free and works fine.  Greenbow has a 64 bit client as well.  Personnaly I prefer free.
pudawat Fri, 01/29/2010 - 16:57
Cisco Doesn't have an IPSec client for Windows 7 64 bit.It is going to be released later this year.Right now only anyconnect client is the option and that is too ver 2.4x and above(If Cisco is your priority ;-p)
Pradhuman
Phillip Remaker Fri, 02/19/2010 - 11:17
  • Cisco Employee,
February 18, 2010
Due to popular demand, the Cisco VPN Client v5.0.7 open beta is now available!
In addition to serving as a general maintenance release, the Cisco VPN Client 5.0.7 beta is compatible with Windows 7 & Windows Vista 64-bit environments.
A 64-bit specific compatible image is available for installation on these platforms.
Please have communicate feedback (both positive and problems) to [email protected].
Key Capabilities available for Beta Testing:
New Platform support – Windows 7 & Windows Vista 64-bit platform compatibility
Software Access: http://tools.cisco.com/support/downloads/go/Redirect.x?mdfid=281940730 (under 5.BETA)
Software is available for download by any customer with a Cisco.com SMARTnet™ enabled login.
Release Notes will be available next week via a link once the download image is selected.
