CUCM, CDR password recovery
Answered Question
Nov 30th, 2009
I have a CUCM installed version 6.1.2.1000-13. Today I tried to enter to: Cisco Unified Serviceability -> Tools -> CDR Analysis and Reporting but I found out that I needed to enter a password. I tried to enter with the user and pass that I use to admin CUCM but this password doesn't work.
Some one told me that sometimes at install you configure a different password for the DataBase. Does any one know how can I do a password recovery for the CDR Analysis and Reporting section?
I thank you in advance for all your help and your time.
Ramon
Correct Answer by Jaime Valencia about 7 years 1 month ago
Is your user already in the CAR admin group??
There is really no PWD recovery, just the users you add to the CAR admin group so they can access the tool
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
Overall Rating: 4.7 (3 ratings)
Correct Answer
Jaime Valencia Mon, 11/30/2009 - 12:02
java
