Questions about SSL VPN
Nov 30th, 2009
I'm excited about the SPA525G phones connecting to the UC500 over SSL VPN..before I start playing around with this feature, I have some quick questions..
1. Do both UC520 and UC540s support this feature? or only UC540?
2. What is the limit of concurrent users connected via this method?
3. Can both IPsec and SSL be enabled at the same time?
Thanks!
glanders Mon, 11/30/2009 - 15:27
MY understanding - anyone else can chime in as well.
Yes, both support with latest software & firmware, I don't recall the exact versions.
10 SSL VPN 525G is the limit
I assume you mean for other VPN access ? I'm not sure on this.
Not sure that is enough detail for you, but a start.
pro4ianyc Tue, 12/01/2009 - 09:20
Greg,
Definitely a good start.  Thanks for the information.  If the configuration requires more remote phones, can that limit of 10 SSL VPN be upgraded with purchasing an additional license?
Eivind Jonassen Thu, 12/03/2009 - 11:56
  • Silver, 250 points or more
Maybe the SR520 router would help?? I think this one has more VPN licenses than the UC500.
Eivind
No, sorry, it doesn´t
Message was edited by: Eivind Jonassen
