LMS3.1 Solaris - Topology services screen
Answered Question
Nov 30th, 2009
Hi, I have a new problem.
In other cliente machine when I try to lunch CM-Visualization_ Topology services, I get this error (attach: topology services.jpg)
I done many thnigs to try to sole. but I can´t.
Please, any idea?
thanks very much in advance!
best regards,
Jorgelina
Correct Answer by Joe Clarke about 7 years 7 months ago
Uninstall the Java Plug-in from the client.  Then, login to the client machine as a local Administrator, and reinstall the plug-in from the LMS server.  Then, as a local Administrator, launch Topology Services.  It should work.  Once it does, you can run TS as a normal user.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Mon, 11/30/2009 - 15:01
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
