ddns config...
Nov 30th, 2009
I can't seem to get ddns to attempt to work.  'debug ip ddns update' shows nothing.  Here's what I have:
ip domain-lookup
ip name-server 192.168.1.2
ip ddns update method DynDNS
HTTP
  add http://username:[email protected]/nic/update?system=dyndns&hostname=[email protected]/nic/update?system=dyndns&hostname=<h>&myip=<a>   remove http://username:[email protected]/nic/update?system=dyndns&hostname=[email protected]/nic/update?system=dyndns&hostname=<h>&myip=<a>
interface Dialer1
ip ddns update hostname myhost.dyndns.org
ip ddns update DynDNS
Any clues?  I don't get any activity.
Overall Rating: 4 (1 ratings)
Armando Yesua G... Thu, 12/03/2009 - 13:55
  • Cisco Employee,
Hi, it looks like some details are missing in your config, and not sure if you are using your user/password.
config t
    HTTP
add
&myip">http://dataserve:[email protected]/nic/update?system=dyndns&hostname=&myip=
example: add
http://horizonsit:[email protected]/nic/updatesystem=dyndns&hostname=kytc.dnsalias.net
    interval maximum 1 0 0 0 ----> (dd/hh/mm/sec)
    exit
  int fa0/0
    ip ddns update
Applying the configuration is :
interface Ethernet1
no ip ddns update DUM_Eth1 host 127.0.0.1
exit
ip ddns update method DUM_Eth1
HTTP
  rem
http://172.16.59.2/cgi-bin/dns//
  add http://test:[email protected]/nic/update?system=dyndns&hostname[email protected]/nic/update?system=dyndns&hostname
=&myip=
Please note:
test is your username given from your ddns server
test1 is your password
members.dyndns.org = the url of the ddns server
For you to be able to type the "?" symbol please use:   control  v  ?
For this to take effect we need to shut and no shut the interface.
Useful commands/ debugs to verify the configuration
show ip host-list
show host x.x.x.x where x.x.x.x is the ip address of (say) members.dyndns.org
show running-config | incl host-list
show ip ddns update
show ip ddns update method
Hope this help.
snickered Thu, 12/03/2009 - 15:08
What I have actually ended up working.  But for some strange reason I have to actually reboot the router (maybe just reset the interface but can't do that since I'm doing it remotely) to make changes to ddns.  So, upon enabling ddns I have to reboot and to even change the URL I have to reboot also.  So, my working config in it's simplest form is like this:
ip ddns update method dyndns
HTTP
  add http://username:password@ members.dyndns.org/nic/update?system=dyndns&hostname=&myip=
interface Dialer1
ip ddns update hostname myhost.mydomain.com
ip ddns update dyndns
