save debug settings between reboots
Nov 30th, 2009
I have a small network at a remote site and I am trying to catch a random problem related a T1 line issue. I have a remote syslog server at the site that I am sending my debug outputs to. My problem is the power at this site is poor and even with a good UPS sometimes the batteries don't out last the outage and the router gets rebooted. My question is, can I save my debug settings so they stay persistent between reboots.
Overall Rating: 5 (1 ratings)
mlund Tue, 12/01/2009 - 06:30
  • Silver, 250 points or more
No You can't save debug, so it restarts after boot,
But
You can probably use eem script to restart it
I haven't done it myself, but something similar to this may work
event manager applet Debug-restart
event syslog pattern "SNMP agent on host ROUTER is undergoing a cold start"
action 1.0 cli command "enable"
action 1.1 cli command "debug whatever"
/Mikael
Richard Burts Tue, 12/01/2009 - 14:52
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Mikael is correct that you can not directly save the debug settings using copy run startup. But there is a technique that will get you the results that you want. Give this a try:
- copy and paste the running config into a text file.
- at the bottom of the text file insert the debug commands that you want the router to perform.
- save the text file.
- tftp the text file to the router startup-config
Since the router executes the commands in startup config it will load the config and then it will execute the debug commands. I have used this a time or two and it works quite well.
The EEM solution suggested by Mikael is probably a more elegant solution. But including the debugs in the text file and tftping to startup does work.
Rick
