Static vs BGP Learned route
Answered Question
Nov 30th, 2009
I will be adding a 2nd ISP as a failover to an establshed config. Current setup uses BGP but I am NOT getting default 0.0.0.0 from the provider. I use static ip route 0.0.0.0 ... to get the traffic out. The failover provider IS going to send me 0.0.0.0/0. Question is will the static prevail over the BGP learned route or will I need to modify AD on static or weight the new neighbor? (Or in it's base form, which is preferred, static or BGP?)(Or, how do you equate AD which prefers lower # to weight which prefers higher #?!)
I had originally thought about filtering out the default and using IP SLA, but would like to keep it simple if possible. I could also try to get ISP 1 to send default, but he's one of the big boys and I'd like to get this done in the next few days.
Correct Answer by Jon Marshall about 7 years 5 months ago
The static route you have configured will take precedence because it will have the lowest AD, which sounds like what you want.
Jon
Overall Rating: 5 (1 ratings)
Correct Answer
Jon Marshall Mon, 11/30/2009 - 15:31
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Jon
