Configuring WAN Simulator with WAAS
Answered Question
Hi all,
I have a remote site in Pune India and I am trying to set up a WAN simulator to simulate the WAN link with WAAS to Pune. Below is the topology and questions.
Server farm <-- WAN simulator PC --> 3750 layer 3 switch <-- client PCs
Questions:
1 - Where would I place the WAAS device ?
2 - I only have one spare WAE for this test. Can this scenario work with only one WAE ? or do I need two WAEs (one on each side) for WAAS to work ?
3 - Do I need a Central Controller for WAAS to function ?
Thanks in advance !!! I appreciate any inputs / suggestions !!
Danny
Correct Answer by rvavale about 7 years 6 months ago
Hi Danny,
On the second WAE, you need to configure WCCP just like its configured on first WAE. And WCCP will
redirect traffic to both of these WAE's.
There are Two Algorithms for redirecting traffic,
- Hash
- Mask
WCCP intercepted traffic is forwarded to WAE based on bucket placement algorithm, hashing or masking with
IP addresses.
This link explains on wccp redirection,
http://www.cisco.com/en/US/docs/solutions/Enterprise/Data_Center/WAASDC11.html#wp95583
Attached pdf file explains in detail on wccp and redirection methods,
Hope this helps,
Best Regards,
Rahul
Hi Danny,
You need Two WAE Devices, one at Branch site and second at Data Center site for WAAS to optimize traffic across the WAN.
WAAS optimization always happens between two WAE devices. You can have more than one WAE at each site based on traffic volume and other network factors.
You also need Central Manager to manage WAE's, their policies and for reporting.
This link provides Technical overview of WAAS software version 4.1,
https://www.cisco.com/en/US/prod/collateral/contnetw/ps5680/ps6870/prod_white_paper0900aecd8051d5b2.html
Hope this helps,
Best Regards,
Rahul
Overall Rating: 5 (2 ratings)
Correct Answer
rvavale Tue, 12/01/2009 - 13:04
  • Cisco Employee,
Hi Danny,
Hope this helps,
Best Regards,
Rahul
Hi Rahul,
Thanks for your reponse !!! I have another question for you. Currently I have 4 remote sites in my production WAAS network and I am planning on adding a few more remote sites in the near future and to handle the additional remote sites I am planning on adding one more WAE at the data center site. I would like to find out how to redirect traffic at the data center when you have more than one WAEs and currently I am using WCCP for traffic interception. Does WCCP load balance traffic by default ? is there any special configuration on the routers or the WAEs for traffic load balancing ?
Thanks again Rahul !!! I appreciate your help !!!
Danny
Correct Answer
rvavale Wed, 12/02/2009 - 01:17
  • Cisco Employee,
Hi Danny,
- Hash
- Mask
IP addresses.
Hope this helps,
Best Regards,
Rahul
