SPA400 constantly rebooting
Answered Question
Dec 1st, 2009
I have a problem with a SPA400 constantly rebooting.
The problem occured when I did some changes in the "Voice"-tab.
I changed the "Caller ID/CP Tone Method" from american to european, and the SPA400 started rebooting constantly.
The only way I could avoid this was to reset the device and change the "Caller ID/CP Tone Method" before I did anything else.
But now I'm afraid to do any changes in the future, in case it breaks down again.
What could be the cause of this problem?
Øystein
Correct Answer by Patrick Born about 7 years 7 months ago
Hi Øystein,
Engineering are investigating several issues on the SPA400. I've shared this thread with them.
Patrick
Correct Answer by jim.snowdon about 7 years 7 months ago
Just cam across another thread with similar problem:
https://www.myciscocommunity.com/message/10474#10474
There is a link to newer (beta??) firmware 1.1.2.3 which might help your situ ?
Jim
Overall Rating: 5 (2 ratings)
jim.snowdon Tue, 12/01/2009 - 03:31
I had similar problems after upgrading the firmware to 1.1.2.2, made some changes via the web interface and hey presto same problem as you. It got so bad that even a factory default reset would be ineffective and could not gian access to the interface at all. Had to return the unit for replacement.
Now the replacement is displaying odd behavoir after upgrade to 1.1.2.2 in that no changes via web interface are retained after restart. I too want to change the "Caller ID/CP Tone method" from "UK BT" to "UK CCA" as all my outbound calls on the FXO's are mis-dialing. Looks like another RMA case!
Possibly 1.1.2.2 is faulty firmware ?????
Jim
oehveding Tue, 12/01/2009 - 03:50
Well, I'm using firmware 1.1.2.2 myself. So that might be the problem.
I think the web-UI is working really slow as well, so it might be a faulty firmware as you say..?
Øystein
oehveding Tue, 12/01/2009 - 04:32
Hi, Jim
Thanks for the link. I'll try that and se if it helps!
Øystein
Correct Answer
Patrick Born Thu, 12/03/2009 - 14:47
  • Cisco Employee,
Hi Øystein,
Patrick
