Unable to establish vpn on Anyconnect
Dec 1st, 2009
Helo,
I'm trying to establish a vpn connection between an ASA with ios 8 and a Cisco Anyconnect client 2.4 on Windows Vista 64bits. I get the message "Unable to establish vpn connection" before the requested login data. I've trying in other pcs with the shame configuration and normally i can connnect, but i have some pcs that i can't. This is the response from the ASA:
Oct 23 2009 13:16:27: %ASA-4-113019: Group = clienteany, Username = admin, IP = XXX.XXX.XXX:XXX, Session disconnected. Session Type: SSL, Duration: 0h:00m:03s, Bytes xmt: 10113, Bytes rcv: 61025, Reason: User Requested
In the anyconnect event viewer it seems that there is a problem with the certificate on windows, but i can't resolve it, i'm trying to install it manually but it doesn't work:
Function: CertVerifyCertificateChainPolicy
Return code: 0x800B010F
File: .\Certificates\CapiCertificate.cpp
Line: 1793
Description: El nombre CN del certificado no coincide con el valor pasado.
Can anyone help me???
hitsmobile Tue, 12/01/2009 - 01:11
Sorry, the message "unable to establish vpn" appears after introducing login data, not before. I was mistaked. Thanks
busterswt Wed, 12/09/2009 - 17:07
  • Bronze, 100 points or more
Are you using only the two built-in AnyConnect licenses? You will get a login failed type message upon the 3rd+ consecutive login attempt if the 2 licenses are in use.
Just a thought!
- James
