RME baseline templates
Dec 1st, 2009
I have switches and routers.
Im trying to manadge them from rme 4.2.
I would like to run comand in global mode:
ntp server 10.1.1.100
but only on the devices, which dont have already running:
sntp server 10.1.1.100
my template is:
Name: DefaultPreReq     SubMode: No      isPrerequisite: Yes
Ordered : No     Prerequisite-Commandset : none     Parent: none
  -   sntp   server  [#.*#]
Name: Commands     SubMode: No      isPrerequisite: No
Ordered : No     Prerequisite-Commandset : DefaultPreReq     Parent: none
  +   ntp   server   10.1.1.100
Pleas help...
Joe Clarke Tue, 12/01/2009 - 09:34
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You are seeing my bug CSCsv25190.  This bug is fixed in RME 4.3 (LMS 3.2), and a patch for RME 4.2 is available from TAC.  Essentially, negative prerequisites do not work.
Valery.Laptev_2 Tue, 12/01/2009 - 21:51
As I understand:
on RME 4.2 negative prprerequisites do not work.
on RME 4.3 negative prprerequisites work.
And to fiix the problem, I should use patch 4.3?
Joe Clarke Wed, 12/02/2009 - 00:12
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
The recommended fix is to upgrade to LMS 3.2 which includes RME 4.3.
Valery.Laptev_2 Wed, 12/02/2009 - 06:00
Thank you for help!!!
Last Q-tion is:
If i have licens for LMS3.1      300 devices.
Should I buy new licens to instal LMS 3.2???
Joe Clarke Wed, 12/02/2009 - 11:02
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You do not need a new license for LMS 3.2.  Your existing LMS 3.1 license will work just fine.
laptev.valery Tue, 12/29/2009 - 05:10
Good Day!
Were from I can download LMS 3.2 ???
I have used "search", but coulden"t get the correct result.
Pleas, recomend me link to download:)
Related Content
