How to connect 2 triggers ?
Dec 1st, 2009
My script needs to call 2 external contacts (2 different triggers) and make them connect.
So i'm using "Place Call" Step for the 2 calls, and when they're connected, I don't find a way to connect them together...
Can someone help ?
Thx
Fabian
Overall Rating: 4 (1 ratings)
Jonathan Schulenberg Tue, 12/01/2009 - 06:33
This is, unfortunately, not possible within IP IVR or CCX. There is no way to join or conference contacts together. I would suggest adding yourself to the PER through your Cisco AM.
