Chassis WS-C6509-NEB and without NEB
Answered Question
Dec 1st, 2009
What is different bettwen these two chassis? WS-C6509-NEB and WS-C6509
I'm thinking abou this two bundles WS-C6509-2500AC=  and  WS-C6509NEB-1300A=, do i have to get fan separately?
thanks
Correct Answer by Giuseppe Larosa about 7 years 5 months ago
Hello R.Siripan,
if this question is related to your other thread the one when you ask about a bundle with FWSM it would be wise to go on there
A link to various chassis datasheet is:
http://www.cisco.com/en/US/prod/collateral/modules/ps2797/ps5138/product_data_sheet09186a00800ff916_ps708_Products_Data_Sheet.html
so you can compare several parameters
Also if your account has enough privileges you can take advantage of IOS software advisor that can help you to build your chassis
see
http://tools.cisco.com/Support/Fusion/FusionHome.do
it is a little slow but it is smart enough to suggest you the right FAN type depending on linecards
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Correct Answer
Giuseppe Larosa Tue, 12/01/2009 - 07:05
  • Hall of Fame,
    Founding Member
Hello R.Siripan,
see
Hope to help
Giuseppe
grplante Tue, 12/01/2009 - 07:27
The Standard 6509 Chassis has a right to left air flow, where as the NEB chassis bring the air in from the front and blows it vertically thru the chassis and exhausts it out the rear.
The NEB chassis is also taller and the slot are vertical.
The Fan you select will be determined by the  line cards you are using, for example you would need the high speed fan tray if you plan on using the Sup720.
Hope that helps.
GP
