12-01-2009 08:43 AM
Hi ,
I need to connect two offices ( two different LAN's) together using cisco 1841 routers at both end.
Currently both cisco router are in working order and acting as a internet gateway to the LAN clients. ( doing NAT).
Can anybody please advise what is the easiest method to configure VPN between two sites so that LAN users at one office be able to access the email/application servers at the other LAN office.
I understand I need IPSec Site to Site VPN ( i think).
Can anyonce please advise.
Regards.
Solved! Go to Solution.
12-01-2009 09:00 AM
s.nasheet wrote:
Hi ,
Regards.
Yes, you do need a site-to-site VPN. Start with this link which gives a number of examples for configuring a S2S VPN between 2 Cisco routers -
http://www.cisco.com/en/US/tech/tk583/tk372/tech_configuration_examples_list.html#anchor16
Jon
12-01-2009 09:00 AM
s.nasheet wrote:
Hi ,
Regards.
Jon
12-01-2009 09:04 AM
Jon,
Thanks.
