12-01-2009 08:55 AM - edited 03-18-2019 10:53 AM
Working on a CM 7.1(3) with local user database and extension mobility. User device profiles are associated with each user ID. The corporate directory on the phones show the primary number of the UDP, but the directory on the ccmuser web page automatically shows all the phone numbers associated with a user's UDP. Some of these numbers are private lines. Is there any way to block certain UDP lines from showing up in the directory, or to turn off the directory from being an option on the ccmuser web page?
Solved! Go to Solution.
12-01-2009 09:43 AM
In Enterprise Parameters search for:
12-01-2009 09:43 AM
12-01-2009 09:53 AM
That'll work! Thanks!
