OER - Active Probing
Answered Question
Dec 1st, 2009
Dear Experts,
I am going thru OER configuration. While coming across CREATION OF ACTIVE PROBES, I learned that ative probes are synthetic/simulated traffic using IP SLA features.
I also understood that 2 types are there viz. Learned probes & Configured Probes.
Configured Probes are created using command active-probe under oer master. Then what is the difference between configuring active probes using IP SLA MONITORING and using ACTIVE-PROBE command. Is both are same?
Thanks in advance
sairam
Correct Answer by Jon Marshall about 7 years 7 months ago
snarayanaraju wrote:
Dear Experts,
Thanks in advance
sairam
Sairam
OER just uses IP SLA underneath the hood so to speak. So by configuring an active probe within OER you are actually using IP SLA monitoring, just that you don't have to explicitly type out all the ip sla configuration.
Jon
Overall Rating: 5 (1 ratings)
Correct Answer
Jon Marshall Tue, 12/01/2009 - 12:10
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Dear Experts,
Thanks in advance
sairam
Sairam
Jon
hclisschennai Tue, 12/01/2009 - 22:14
Thanks Jon,
I got it. But now in this new screens I am not able to vote or rate yours solutions.
However I will rate full and I got the solution from your answer
sairam
