FWSM on VSS, interchassis link.
Capacity planning for interchassis links is an important part of VSS deployment. Include capacity for FWSM failover pairs to account for failover/state VLAN links between the two chassis if FWSM interchassis failover is deployed. It is recommended to set aside 1-2Gbps for this purpose.
Now, I'm using two 10Gb interface for VSL.
May I use two 1Gb interface, always on SUP720 to build a dedicated GEC for failover pairs only?
Thanks.
Andrea
e-chuah Wed, 12/02/2009 - 00:59
Hi..
I don't think u can use the 1G link in the Sup720 to build a GEC for the failover pair.
THis is because the entire VSS is treated as one switch. If u connect the GE port in Switch1 to Switch2,
from VSS perspective, u are looping back the connection to itself.
Rgds
Eng Wee
