Unity 7 VM .wav volume too low
TKUZMA1022_2
I just converted to Unity 7 UC and some users are complaining that the volume on the .wav files is too low even when they have the volume turned up all the way. I saw other posts from unity 3, etc.. that wanted you to adjuct the gain levels on the voiceports. Is that still valid and if so, do I adjust them on the remote side that is experancing the low volume issue.
Thank you for your help.
Tom
Thomas,
Please check the following guide for troubleshooting volume issues with Unity connection:
"Problem with the Volume of Recordings"
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/7x/troubleshooting/guide/7xcuctsg060.html#wp1052958
It will explain how to adjust volume.
HTH,
pablogon
Thanks for your reply. I saw that artical also. I was looking for confermation. I will follow the process described.
