Info Digit AS5400
Dec 1st, 2009
Our current setup is basically Cisco AS5400 -> Lucent Excel Switch
We are trying to setup a new VoIP connection to receive calls with info digits so that we know if a person is calling from a payphone or not.
The call itself goes through to our switch and connects, but the info digit is not being forwarded.
The new vendor gives two options on where the info digit will be placed.
In the invite message or the from message.
INVITE sip:[email protected];isup-oli=00 SIP/2.0
From: "1234567890" <sip:[email protected];isup-oli=00>;tag=9jZvvUFj41e7o
As you can see, they are sending the line "isup-oli=00"
When I debug ISDN, I'm not seeing anything that seems remotely close to an info digit.
I've search online and found words like codeset, Locking shift, but none of those shows up on the debug.
ISDN GTD is enabled on the serial interface.
.Dec  1 15:10:00.675 UTC: ISDN Se7/0:16:23 Q921: User TX -> INFO sapi=0 tei=0, ns=38 nr=43
.Dec  1 15:10:00.675 UTC: ISDN Se7/0:16:23 Q931: SETUP pd = 8  callref = 0x0094
        Sending Complete
        Bearer Capability i = 0x8090A2
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98395
                Exclusive, Channel 21
        Calling Party Number i = 0x2180, '1234567890'
                Plan:ISDN, Type:National
        Called Party Number i = 0xA1, '4321'
        Redirecting Number i = 0x00008F, '0987654321'
                Plan:Unknown, Type:Unknown
.Dec  1 15:10:00.675 UTC: ISDN  Q921d: isdn_l2d_srq_process: event_count 1
.Dec  1 15:10:00.691 UTC: ISDN  Q921d: isdn_from_driver_process: QUEUE_EVENT
.Dec  1 15:10:00.691 UTC: ISDN Se7/0:16:23 Q921f: User RX <-
.Dec  1 15:10:00.691 UTC:       0201564E08028094021803A98395
.Dec  1 15:10:00.691 UTC: ISDN Se7/0:16:23 Q921: User RX <- INFO sapi=0 tei=0, ns=43 nr=39
.Dec  1 15:10:00.691 UTC: ISDN Se7/0:16:23 Q931: CALL_PROC pd = 8  callref = 0x8094
.Dec  1 15:10:00.691 UTC: ISDN Se7/0:16:23 Q921d: process_rxdata: Frame sent to L2
.Dec  1 15:10:00.691 UTC: ISDN Se7/0:16:23 PACKET: L2IF_SendPkt:
        source_id (0x200), state (0x0),
        dest_id (0x20A), event (0x141),
        sapi (0x0), ces (0x0), call_id (0x0),
        chan_id (0x0), int_id (0x6A2F3BC0), free_pkt (0x1),
        pkt (0x653F8E7C), msecs (0x0), priority (0xA)
.Dec  1 15:10:00.691 UTC: ISDN Se7/0:16:23 PACKET: L2IF_DispPak: packet - start(2001C558), size (14)
.Dec  1 15:10:00.691 UTC: ISDN Se7/0:16:23 PACKET: L2IF_SendPkt: Sending from L2
        dest_id = 0, source_id = 512, prim = 141
        priv_ln = 4, int_id = 1781480384
We are using IOS c5400-jk9s-mz.124-22.T.bin
And configurations are:
hostname TEST
boot system flash:c5400-jk9s-mz.124-22.T.bin
no boot startup-test
logging console critical
enable secret 5
resource-pool disable
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
clock timezone EST -5
clock summer-time EST recurring
spe default-firmware spe-firmware-1
no ip source-route
ip cef
no ip bootp server
no ipv6 cef
isdn switch-type primary-4ess
isdn voice-call-failure 0
isdn gateway-max-interworking
voice hunt user-busy
voice call send-alert
voice call carrier capacity active
voice rtp send-recv
voice service pots
voice service voip
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711ulaw
trunk group TEST
hunt-scheme random
controller T1 7/0:16
framing ESF
pri-group timeslots 1-24
interface Serial7/0:16:23
no ip address
encapsulation hdlc
trunk-group TEST
isdn timer T310 60000
isdn not-end-to-end 64
isdn incoming-voice modem
isdn guard-timer 3000
isdn send-alerting
isdn sending-complete
no cdp enable
dial-peer voice 1234 pots
trunkgroup TEST
permission term
description TEST
destination-pattern 1234
forward-digits 4
dial-peer voice 1235 voip
permission orig
description TEST
  session protocol sipv2
session target
incoming called-number 1234
no vad
timer receive-rtp 1200
set pstn-cause 16 sip-status 503
set pstn-cause 63 sip-status 503
ss7 mtp2-variant Bellcore 0
ss7 mtp2-variant Bellcore 1
ss7 mtp2-variant Bellcore 2
ss7 mtp2-variant Bellcore 3
If there is any information i've missed or more information is needed, please let me know.
Does anyone have any idea on what might be wrong?
Any kind of help would be greatly appreciated. Thank you.
Related Content
