Secure Desktop Advanced Endpoint Assessment
Dec 1st, 2009
I have licenced and enabled Advanced Endpoint Assessment, however it does not seem to be returning definition update status, nor is it enforcing updates on products that have a note stating it should be supported.
Any tips for using this feature?
dbgreekas Wed, 12/02/2009 - 10:08
I have turned on debug level logging for secure desktop, and there is still no indication that any remediation attempt is taking place in the clients logs.
There seems to be little or no feedback from the system that Advanced Endpoint Assessment is working at all.
Does anyone actually use this feature?
dbgreekas Wed, 12/02/2009 - 15:55
Dissabling the keylogger scan and Virtualization scans appears to have fixed my AV Advanced Endpoint remediation issue.
Seems that the Keylogger is often blocked as malware by many AV products or simply times it self out. If this happens none of the advanced enpoint remediation is performed and there for non the the more detaild endpoint variable are returned for DAP.
