Xbox - NAT
Dec 1st, 2009
Hi i am new to this community.
I'll try to give as much information as i can.
I basically know nothing about networking and routers and such. That's why i need your help, the professionals. So my xbox 360 sits in my room. To play
Live it requires internet connection. I have my Ethernet Cable hooked up to the back of it, the other end is connected to my router. My router is connected
to my modem. So my Xbox live works fine. Just fine. I play Halo3 and whenever it searches for people, it messages me that my NAT is set on strict and
my connected is limit in a way. Recently i am not able to play with my buddies because of this "strict NAT".I have a Buffalo AirStation WBR2-G54. I have
sort of researched online sources to see how i can make my "NAT" to open. So what i have found is that i have to go to my router settings and open ports.
Which i have done so, however...it has done absolutely nothing. Maybe i am doing something wrong? Is there another way?
Can someone please help! If i am posting this in the wrong section, sorry!
Desperate man.
hobbe Wed, 12/02/2009 - 00:58
  • Gold, 750 points or more
The ports you need to open are
UDP 88,3074,3330
and
TCP 3074
Those ports have to be open from anyone on the internet to your X-box.
How you open a nat port in a buffalo unit I do not know you have to ask their support for that information.
On a cisco you would use a static from the ip (or interface) that the ISP is giving you to the ip of the X-box and added access-lists to permit for it to pass through.
A good thing to think about is to not have the X-box on the same network as all the other stuff if you can avoid it. If you have the ability to separate it with its own physical network or if need be V-Lan (better than nothing) its a good thing.
Good luck
Juicy_grape Wed, 12/02/2009 - 16:42
Could someone please elaborate on this? I am a total noob at networking and such.
Thanks!
hobbe Thu, 12/03/2009 - 13:00
Ok lets make a quick and a quite simplified walkthrough.
You have a firewall/broadband router/nat device to block direct contact between your machines and the Internet with all the dangers out there.
One reason for having this device (firewall...) is that many softwares have bugs in them, or are misconfigured and thus can get compromised.
When you make holes through the firewall into your equipment you essentially take away or minimizes the protection of the firewall for that hole.
That is why you want the hole to be as small as possible ie if you can open one single port for a ip address, it is better than opening a whole ip address with all the ports. The less you expose the less vulnerabilities are available for the hacker/worm/virus to explore.
One reason why you would want to separate the computer you are exposing to the Internet from all the other computers is that if it gets compromised ie someone hacks it and takes control of it, they will se whatever that computer sees.
That means that IF the computer is placed on a separate network from the other computers, then it will not see/have direct contact with the other computers and hopefully that would mean that you only would loose one computer and have to reinstall that one instead of reinstalling all of them.
Juicy_grape Thu, 12/03/2009 - 19:35
Ahh i see!
So what steps should i be taking to make everything work?
hobbe Thu, 12/03/2009 - 23:59
Well the first thing you need to do is to decide your network topology ie how do you want things to look and weight pros and cons against eachother.
a tip might be that the xbox does not use dhcp only static address.
When you have the design you want ( do you want to use a DMZ or not?) then you go to the support forum of your buffaloairstation and ask them on how to do it. Basically the same question you asked here, but now you already know the ports you need to open.
The reason that we can not answer exactly how you do it here is that every maker have their own way of doing things. A cisco device is not configured in the same way as fx a d-link, clavister, fortinet or buffalo device, not even the terminology is the same. If we (cisco ppl) speak of default gateway here, then they (other vendors) might call it gw-world or gateway of last resort. It means the same thing but the terminology and how to set things up is not the same.
In a cisco device you would have made statics for the ports and ip addresses needed and then added access-lists allow the traffic through. But since noone here seems to have a buffalo airstation noone knows how they do it in a buffalo device.
So it is not that we do not want to help you it is just that you are in the wrong forum, you need people who knows buffalo airstations and how they are configured. so go to http://www.buffalo-technology.com/home/ and choose support and look there for how to open ports.
Related Content
