Problem with EssentialsDM
Answered Question
Dec 2nd, 2009
I (my customer) have similar problem like described in this discussion:
https://supportforums.cisco.com/message/669826#669826
EssentialsDM is stuck in "waiting to initalise" state. Problem started to occurring around a last thursday.
EssentialsDM.log, EssentialsDM_Server.log and pdshow attached.
Mladen
Correct Answer by Joe Clarke about 7 years 2 months ago
It appears you have the Windows remote management service started which listens on tcp/47001.  This port is required by EssentialsDM.  Can you disable Windows RM, and see if that helps?
Overall Rating: 5 (1 ratings)
Joe Clarke Thu, 12/03/2009 - 08:45
Shutdown Daemon Manager, then port the output of the command "netstat -a -n -o -b".
Correct Answer
Joe Clarke Fri, 12/04/2009 - 11:23
mladenp Mon, 12/07/2009 - 04:01
Yes, it helps. Everything is OK again.
Thank you very much,
Mladen
