6509 vss issue
Dec 2nd, 2009
     Hi all,
                     I configured 6509 VSS one of my customer,while chaecking failover. First i shut down the active switch traffic is going through secondary switch.Afterwards i restared active switch but that time secondary switch is also the reinsalaies all the port. Its takes 50 sec to come back so they consider that time down time.what might be the problem.
Thanks in advance
chandru.j Wed, 12/02/2009 - 03:03
  I am using BFD for dual active detection.
Giuseppe Larosa Wed, 12/02/2009 - 05:02
  • Hall of Fame,
    Founding Member
Hello Chandru,
and you have a dedicated direct link for BFD packets to flow between the two switches?
I suppose you have the dedicated link
what IOS version is running on the VSS pair?
Hope to help
Giuseppe
Reza Sharifi Wed, 12/02/2009 - 20:19
  • Cisco Designated VIP,
    2017 LAN
In a VSS enviremnt, you should not have any down time at all.  I have tested this many times with no issues. The reason for your primary box rebooting is because you have preeamtion configure.
After looking at your config, one thing I suggest is that you should delete priority and preemption, save your config and test again.
Reza
chandru.j Wed, 12/02/2009 - 20:40
  Here i need to clarfiy one thing primary is not rebooting.For failover testing i am shuting down the primary switch and checking the connectivity through ping form the server to router its happening fine.While powering up the primary switch again the secondary switch is rebooting.Now waht i have to do same as you said can i delete preempt and priority.Kindly let me know this.
Chandru
Reza Sharifi Thu, 12/03/2009 - 06:15
    2017 LAN
Chandru,
Yes, remove priority and preemption
Make sure to SAVE the config.
Now reboot again and test.
In a scenario where you do not have priority and preemption, if you reboot both switches at the same time, switch-1 will always be the primary and switch-2 is the back up which you don't have access to make any config changes.
Reza
Swandip Ranjan Dhar Fri, 11/29/2013 - 00:36
Hi Guys,
I am also having the same problem...
We have seen issue when any of our VSL link goes the entire VSS pair goes down and even if the primary unit fails the secondary unit dont take over...
Another Q if the primary unity SUP fails will the secondary pair of  SUP engine will suport  the primary switch or the primary will be down that time.
Please check the attachment for our VSS config...
switch virtual domain 10
switch mode virtual
dual-active detection pagp trust channel-group 1
dual-active detection pagp trust channel-group 2
interface Port-channel101
no switchport
no ip address
no platform qos channel-consistency
switch virtual link 1
end
interface TenGigabitEthernet1/5/5
no switchport
no ip address
no cdp enable
channel-group 101 mode on
end
interface TenGigabitEthernet1/5/4
no switchport
no ip address
no cdp enable
end
interface Port-channel102
no switchport
no ip address
switch virtual link 2
end
interface TenGigabitEthernet2/5/4
no switchport
no ip address
no cdp enable
channel-group 102 mode on
end
interface TenGigabitEthernet2/5/5
no switchport
no ip address
no cdp enable
end
module provision switch 1
slot 1 slot-type 147 port-type 61 number 48  virtual-slot 17
slot 2 slot-type 147 port-type 61 number 48  virtual-slot 18
slot 3 slot-type 284 port-type 60 number 16  virtual-slot 19
slot 4 slot-type 284 port-type 60 number 16  virtual-slot 20
slot 5 slot-type 318 port-type 31 number 3 port-type 60 number 2  virtual-slot 21
slot 7 slot-type 156 port-type 31 number 24  virtual-slot 23
module provision switch 2
slot 1 slot-type 147 port-type 61 number 48  virtual-slot 33
slot 2 slot-type 147 port-type 61 number 48  virtual-slot 34
slot 3 slot-type 284 port-type 60 number 16  virtual-slot 35
slot 4 slot-type 284 port-type 60 number 16  virtual-slot 36
slot 5 slot-type 318 port-type 31 number 3 port-type 60 number 2  virtual-slot 37
#show switch virtual lin
VSL Status : UP
VSL Uptime : 4 weeks, 6 hours, 30 minutes
VSL SCP Ping : Pass
VSL ICC Ping : Pass
VSL Control Link : Te1/5/4
VSL Encryption : Configured Mode - Off, Operational Mode - Off
#show switch virtual link port-channel
Group  Port-channel  Protocol    Ports
101    Po101(RU)        -        Te1/5/4(P)     Te1/5/5(P)
102    Po102(RU)        -        Te2/5/4(P)     Te2/5/5(P)
