after RestorePortal.pl, no more Portal present
Dec 2nd, 2009
Hallo,
I did a RestorePortal.pl and after this,
it comes the Login Page,
and after the Login only a empty Page/Screen, but no Portal,
on LMS 3.2 and Solaris 10
regards
Alex
Joe Clarke Wed, 12/02/2009 - 10:56
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Post the NMSROOT/MDC/tomcat/logs/stdout.log and the lmsportal.log.
Joe Clarke Wed, 12/02/2009 - 22:16
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Try the portal reinit again.  If that doesn't work, you will need to contact TAC to get new original portal database files as it appears something may have gone wrong with your files.
patrias Wed, 12/02/2009 - 22:27
i tried it but with the same result,
ok i will contact TAC,
thanks
