Regarding default credential sets
Answered Question
Dec 2nd, 2009
Dear friends,
I have created 3 credentials sets and 6 credential set policies.
How do i know if a device has got bound successfully to the default credential set that i created?
Thanks and Regards
Gautam
Correct Answer by Joe Clarke about 7 years 1 month ago
You can export the DCR entry for the device, and check.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Wed, 12/02/2009 - 10:57
gautamzone Wed, 12/02/2009 - 12:00
Thats fine Jason.
I tried doing a RME sync archive to test it but it failed.
I just edited the device credentials directly and used them for RME sync archive and it worked.
Thanks a lot
Gautam
