Clocking Query for E1 Controller
Dec 2nd, 2009
Hi guys,
Only new to the world of clocking so be gentle :-)
I have inherited 4 x 3745 voice routers and am trying to understand why the network clocking is configured the way it is.
On one of the routers there is:
network-clock-participate slot 2
network-clock-select 1 E1 2/1 (this is to the PSTN)
network-clock-select 2 E1 2/0 (this is to our internal PABX)
This makes sense to me that we are taking the clocking from the external service provider.
The other 3 x 3745 routers also contain multiple E1 connections to the external PSTN and internal PABX but are configured to use the backplane for clocking.
i.e. no network-clock-participate for all slots.
From what i have read you are better off using the PSTN connection for clocking rather than the backplane.
There are no slip second errors at all and everything is working fine but I am wondering should i be changing the other three routers clocking sources as a best practice type exercise.
I also have to add a new E1 connection to an internal PABX on one of the routers using the backplane for clocking (with a connection to the PSTN) and am wondering if i leave it as is and use the no network-clock-participate slot for the new card.
Cheers,
G
asandborgh Wed, 12/02/2009 - 05:27
Glenn,
A couple quick questions -
Are all of the external PSTN connections going to the same carrier?
If so are they going to the same CO switch (to your knowledge?
I don't really understand why they would have you PABX as the second clock source - normally you would use a second line to the carrier and the PABX should be clocking from the router via a participate command
Does the PABX have another E1 directly to the carrier?
Art
