web password change for Wireless Lan controller
Dec 2nd, 2009
i am using WLC 2112 in my setup.i am able to login to wlc with https but not getting any option to change the password for the web user.finally i created a new user and gave him the permissipon for the access and been able to login.
can you please suggets me the option to change the password for the existing user using http access..
Ryan Curry Tue, 12/08/2009 - 07:53
I assume you're meaning to log into the WLC from http?  If so, what I've done in the past is create a second user, login as that user then delete/recreate the user you're needing to change.  As far as I'm aware, there's no way to change the password for the admin users.
