Wireless interfaces Radio 0 and Radio 1
Dec 2nd, 2009
Is it possible to turn on both the  radio interfaces Radio 0 and Radio 1.  (  Radio0-802.11N2.4GHzRadio1-802.11N5GHz ). For the SAME SSID. Access Point is 1250 series.  Do we need any extra hardware for this?
Please share the experience.
Any link on cisco.com?
Thanks in advance
Subodh
Overall Rating: 5 (1 ratings)
dancampb Wed, 12/02/2009 - 07:06
Sure.  I assume you're using an autonomous AP.  The SSID is created in global config mode with the dot11 ssid commands.  Then you apply the SSID to which radio interfaces you want with the interface command ssid XXXXX.
bapatsubodh Wed, 12/02/2009 - 08:07
Thanks for you reply. We are having autonomous AP.  What will be the effect of turning on both teh radio interfaces for same SSID any benefit ?
Subodh
Leo Laohoo Wed, 12/02/2009 - 13:55
Q:  What will be the effect of turning on both teh radio interfaces for same SSID?
A:  The SSID will be broadcasted on both radios AND you can enable 802.11n.
How will you be powering the AP?  Power injector or standard PoE (15.4 watts) or PoE+?
Trending Topics - Security & Network
