ACS 5.0 internat host import
Answered Question
Dec 2nd, 2009
Hi All!
I would like to import some hosts to ACS. I know, the ACS give a template in a cvs file, but I don't upload anything. Can you help me?
The template:
MACAddress:String(64):Required,description:String(1024),"enabled:Boolean(true,false):Required",HostIdentityGroup:String(256)
Regads,
Gyuri
Correct Answer by jrabinow about 7 years 7 months ago
The following is the process to import hosts into ACS 5.0
1) Go to
Users and Identity Stores: ... > Internal Identity Stores > Hosts, Press "Import" and then "Download Template"
2) Open the template file. The first line should be left unchanged. Underneath, records should be added with one record for each host
An example of the minimum that needs to be defined for a host is shown below:
11-22-33-44-55-66,,TRUE,                   //// Identity Group is left blank and top level node is assigned
Format of each line is ,,,
Each record occupies one line. Save the file
3) Once the records are created, press "Import". Select the file from "step 2" and press "Start Import". Import of the host records should start. Any errors will be displayed in the progress window
Note that ACS 5.0 allows only to add new rcords. In ACS 5.1, can also modify existing records and export them. ACS 5.1
Overall Rating: 5 (1 ratings)
Correct Answer
jrabinow Wed, 12/02/2009 - 10:49
  • Cisco Employee,
1) Go to
TimurKaneev Mon, 02/14/2011 - 01:32
Hi all!
i try to import hosts and get the error
2011-02-14 12:25:16: File Format Validation Failed
Header is incorrect. Download Import Template for required header record.
i have ACS 5.1
The file has following form:
"MACAddress:String(64):Required,description:String(1024),""enabled:Boolean(true,false):Required"",HostIdentityGroup:String(256)"
10-02-E3-53-EC-9A,,true,All Groups:Vdisk
10-19-DB-2B-A6-2B,first,true,All Groups
10-1B-78-F3-43-4F,,true,All Groups:Printers
10-30-C1-C5-E7-70,,true,All Groups:Printers
What should i do?
jrabinow Thu, 02/17/2011 - 22:17
  • Cisco Employee,
As I mentioned above the first two steps for host import:
1) Go to
Users and Identity Stores:... >Internal Identity Stores >Hosts, Press "Import" and then "Download Template"
As long as you leave the first line from the template unchanged and only add the records underneath the import should fail. You should make sure that there are no new line or extra characters
I have a later release (5.2) but I think this functionality isrelatively unchanged and get the following for the header:
Compare this towhat you have:
It appears that some extra quote characters have appeared. Hard to tell and if you attach the file itself can take a closer look
