How do I remove this line from my 6500?
jfraasch
Level 3
Level 3
spanning-treemode rapid-pvst
no spanning-tree vlan 200,210,220,230,240,250,300,310,320,330,340
spanning-tree vlan 1-2,100,110,120,130,140,150 priority 24576
spanning-tree vlan 200,210,220,230,240,250,300,310,320,330,340 priority 28672
diagnostic bootup level minimal
I don't want to have the second spanning-tree vlan line to show up at all.  They were added but we are changing and will not even have those VLANs on this switch.
I did the "no" command but it just added another annoying line of code.
Any suggestions?
James
chaubcisco
Try this in config mode:
no spanning-tree vlan 200,210,220,230,240,250,300,310,320,330,340 priority 28672
That should do it.
Reza Sharifi
James,
If you are not able to remove all with one command, then try removing them one at the time
Reza
chaubcisco
That should do it.
