12-02-2009 08:38 AM - edited 03-06-2019 08:48 AM
Hi all,
I'm trying to bring up the vlan interface without having a host attached. I've created the vlan interface, assigned ports to the vlan. At this point I just want to use a loopback plug to simulate a device being attached to the port and bring up the vlan interface. This is not working. Is there some caveats needed with the 3560G? Again these are gigabit ethernet ports. my loopback plug works on 10/100 ports (which I've tested).
Binh.
12-02-2009 09:08 AM
I don't have a switch in my lab right now, but I looked and there is a loopback configuration option under the VLAN interface. Try it and let us know.
12-02-2009 10:35 AM
Yup. I tried that. doesn't have any affect in terms of bringing the interface up. Just gives a message: Loopback is a traffic
-affecting operation. Thanks.
12-02-2009 09:14 AM
You could always plug an ethernet cable into two ports on the switch. Spanning-tree will take care of the loop and the vlan interface will come up.
12-02-2009 10:37 AM
Hi Brent,
Tried this also. although it does bring the vlan interface up, I see alot of packets between the two plugged in ports. Should this be the case? I'm also wondering why the loopback plug is not working.
Thanks!
