The PCs can ping both of the router´s ethernet interfaces, but CANNOT go beyond that.
Answered Question
Dec 2nd, 2009
Hi everyone
I have a 2514 and I´m using both ethernet ports (config below).
One is attached to the LAN and the other to a cable modem with a FIXED ip address.
I can make the router see the internet (pings anything) by just adding the classic "ip route 0.0.0.0 0.0.0.0 (gateway´s ip address)"
I know it´s a simple matter to solve (probably just another "ip route" command) and thus I thank you!
IOS (tm) 2500 Software (C2500-IS-L), Version 12.0(28c), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Wed 30-Mar-05 16:33 by pwade
Image text-base: 0x0303E2D4, data-base: 0x00001000
ROM: System Bootstrap, Version 11.0(10c), SOFTWARE
BOOTFLASH: 3000 Bootstrap Software (IGS-BOOT-R), Version 11.0(10c), RELEASE SOFTWARE (fc1)
189-57-241-178 uptime is 19 hours, 52 minutes
System restarted by reload
System image file is "flash:c2500-is-l.120-28c.bin"
cisco 2500 (68030) processor (revision L) with 6144K/2048K bytes of memory.
Processor board ID 05689092, with hardware revision 00000000
Bridging software.
X.25 software, Version 3.0.0.
2 Ethernet/IEEE 802.3 interface(s)
2 Serial network interface(s)
32K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read ONLY)
Correct Answer by Jon Marshall about 7 years 5 months ago
galongagalonga wrote:
No, I do not own the address  189.57.etc
But since I´m a total ******* when it comes to routing I guess that means I did not know I just can´t use that address and have to retort to the 192.168....blablabla
Actually, I did try that as well with the same results, but I can do it again and let you know in a coupla minutes
You do own the 201.17.6.x addressing though right ?
Assuming your internal addressing for PCs was changed to 192.168.1.0/24 your config should look like
int eth0
ip nat inside
int eth1
ip address 201.17.6.16 255.255.255.0
ip nat outside
ip nat inside source list 101 interface eth1 overload
access-list 101 permit ip 192.168.1.0 0.0.0.255 any
Jon
Overall Rating: 5 (2 ratings)
Jon Marshall Wed, 12/02/2009 - 11:51
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Hi everyone
Bridging software.
If the PCs are using private addressing then have you set up NAT on the router. You will need to because private addressing is not routable on the Internet.
Can you post router config and also the addressing used by the PCs.
Jon
galongagalonga Wed, 12/02/2009 - 12:04
Yes, I know that in order to be able to use intranet numbers such as (192.168.0.1-255) it´s necessary to use NAT.
But I tried with both IP intranet numbers (using the commands ip nat inside etc) and regular IP numbers and got the same results: the router can ping everyone, but the internet users can only ping both ethernet ports and do not even reach the default gateway
Jon Marshall Wed, 12/02/2009 - 12:19
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Good, glad to hear it
Now could you post details as per last post ie. config + pc addressing.
Jon
galongagalonga Wed, 12/02/2009 - 12:19
The PC that I want to access the internet has an IP number of 189.57.231.227 mask 255.255.255.0 and a gateway 189.57.231.22
The 2514 has the following configuration:
version 12.0
service timestamps debug uptime
service timestamps log uptime
hostname Router
ip subnet-zero
interface Ethernet0
ip address 189.57.231.225 255.255.255.248
no ip directed-broadcast
interface Ethernet1
interface Serial0
no ip address
no ip mroute-cache
shutdown
no fair-queue
interface Serial1
no ip address
shutdown
ip classless
ip route 0.0.0.0 0.0.0.0 201.17.6.1
line con 0
transport input none
line aux 0
line vty 0 4
end
Jon Marshall Wed, 12/02/2009 - 12:28
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
version 12.0
hostname Router
ip subnet-zero
interface Ethernet0
interface Ethernet1
interface Serial0
no ip address
no ip mroute-cache
shutdown
no fair-queue
interface Serial1
no ip address
shutdown
ip classless
line con 0
line aux 0
line vty 0 4
end
Firstly, have these addresses been allocated to you ie. both public on eth0 and eth1 ?
I suspect the issue is that there is no route back to your LAN addressing. So when you ping from the router itself it works because the router uses the source address of eth1.  Try doing an extended ping on the router using the source ip on eth0 and see if ping works.
If the 189.57 addressing has been allocated to you then you can either -
1) Nat them to the eth1 ip address
OR
2) add a route to the next hop device ie. 201.17.6.1 for your LAN addressing pointing back to 201.17.6.16
if you don't own the 189.57 addressing you only have the choice of natting your LAN addresses to eth1
You say you have tried NAT already, what was the config you tried ?
Jon
galongagalonga Wed, 12/02/2009 - 12:33
But since I´m a total dumbass when it comes to routing I guess that means I did not know I just can´t use that address and have to retort to the 192.168....blablabla
Correct Answer
Jon Marshall Wed, 12/02/2009 - 12:36
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
int eth0
ip nat inside
int eth1
ip nat outside
Jon
galongagalonga Wed, 12/02/2009 - 12:48
THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU!!!!!!!!!!!!!!!!!
(SOB) BOHOOOOO (TEARS)
Jon Marshall Wed, 12/02/2009 - 12:52
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
I take it that it's working now then
Glad to have helped.#
Jon
galongagalonga Wed, 12/02/2009 - 13:11
Yes it is and I thank you again.
I get the feeling the problem was the lack of the "access-list 101 permit ip 192.168.1.0 0.0.0.255 any" command
my gut tells me that cisco products policy are "you can´t do jack unless you especifically allow so", which is nice for security but sucks if you are a newbie
tomorrow I´m going to try to connect the serial port as well (have 2 internet connections): hope I can count on your support should you be around ok?
Jon Marshall Wed, 12/02/2009 - 13:19
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
The acl as you probably realised is what tells the router which packets to NAT. Without that having "ip nat inside" and "ip nat outside" configured wasn't actually doing anything.
It certainly can be a steep learning curve if your'e new to Cisco products
I'll be glad to help out if i'm around but the good news is that there are loads of people on these forums that can do the same so you should be able to get help no matter.
If you do need help make sure you post the config you are working with as this saves both you and the people who might answer some time.
Jon
ok I´m back (this time with another moniker as cisco´s site keeps deleting mine)
This time I´ve also set up the serial connection in order to allow 2 connections to the internet (one cable and the other optic)
The config is as follows:
version 12.0
hostname Router
enable password abc123
ip subnet-zero
interface Ethernet0
ip nat inside
interface Ethernet1
ip nat outside
interface Serial0
ip address 189.57.241.178 255.255.255.252
no ip mroute-cache
no fair-queue
interface Serial1
no ip address
shutdown
ip nat inside source list 101 interface Ethernet1 overload
ip nat inside source static tcp 192.168.1.21 80 201.17.6.16 80 extendable
ip nat inside source static tcp 192.168.1.21 21 201.17.6.16 21 extendable
ip nat inside source static tcp 192.168.1.21 25 201.17.6.16 25 extendable
ip nat inside source static tcp 192.168.1.21 110 201.17.6.16 110 extendable
ip nat inside source static tcp 192.168.1.21 5060 201.17.6.16 5060 extendable
ip nat inside source static tcp 192.168.1.21 65000 201.17.6.16 65000 extendable
ip classless
ip access-list extended WebServer
permit tcp any host 201.17.6.16 eq www
line con 0
password abc123
login
line aux 0
line vty 0 4
password abc123
login
The router is a 2514 with the following config:
WARE (fc1)
Router uptime is 19 minutes
System restarted by power-on
Bridging software.
I can´t seem to make both work. It only accesses through the cable and it seems that after a while it loses connection so I have to reboot the router (rebooting the cable modem will not do the trick)
I really tried everything because I hate bothering others, but newbies + cisco = trouble!
Jon Marshall Sat, 12/05/2009 - 15:50
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
[email protected]
version 12.0
hostname Router
ip subnet-zero
interface Ethernet0
ip nat inside
interface Ethernet1
ip nat outside
interface Serial0
no ip mroute-cache
no fair-queue
interface Serial1
no ip address
shutdown
ip classless
line con 0
password abc123
login
line aux 0
line vty 0 4
password abc123
login
Okay, first things first - do you own the address on your serial interface
Assuming you do there are a couple of things you need to add to your config
1) you need an "ip nat outside" statement under the serial interface ie.
int serial0
ip nat outside
2) You only have one default route on our router pointing to 201.17.6.1 so it will only ever use that link. You need to add another default route so the router will alternate between the  -
ip route 0.0.0.0 0.0.0.0  189.57.241.77
Also bear in mind, your static NATs use 201.17.6.16  so any inbound traffic to your servers will use that link.
Jon
Jon Marshall Sat, 12/05/2009 - 15:51
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
oops !
you also need another nat line ie.
ip nat inside source list 101 interface serial0 overload
Jon
Yes, I do own the serial ip number 189.57.241.178 255.255.255.252: it was the one attached to the serial port at and old configuration I had with a 2500 that worked
I also own the number 189.57.231.225 255.255.255.248: it was attached to the ethernet0 in the defunct 2500 and I no longer use it (bought a 2514 to replace it)
I tried to insert the command you said "ip nat inside source list 101 interface serial0 overload" but it claims "Dynamic mapping in use, cannot change"
Then I found out in http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080094422.shtml what to do
It only solved when I turned off the damn thing and plugued both AUIs from it
However, after I insert the commands you told me we are back to step 1: the router can ping but the client cannot.
Don´t we need another command like "access-list 101 permit ip 192.168.1.0 0.0.0.255 any" for the new interface? It seems that did the trick before right?
Jon Marshall Sun, 12/06/2009 - 05:52
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
[email protected]
It only solved when I turned off the **** thing and plugued both AUIs from it
Well, you could try with a different acl ie.
access-list 102 permit 192.168.1.0 0.0.0.255 any
ip nat inside source list 102 interface s0 overload
try that and see if it works. If not can you post full config again.
Jon
Eugene Khabarov Sun, 12/06/2009 - 12:00
  • Silver, 250 points or more
Hmmm... Why use NAT?  Maybe you just forgotten to configure "ip routing" on this old platform
Jon Marshall Sun, 12/06/2009 - 12:17
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Because the LAN addressing is 192.168.1.x
Jon
ok, I put both commands:
actually, apparently the command was access-list 101 permit IP 192.168.1.0 0.0.0.255 any, as it did not work
either way, as soon as I unplug the cable modem the connection drops. any ideas?
shouldn´t there be some kind of command to tell the router to switch between both connections based on some how of weight/rule/something?
Below the config as it is now:
Current configuration:
version 12.0
hostname Router
ip subnet-zero
interface Ethernet0
ip nat inside
interface Ethernet1
ip nat outside
interface Serial0
ip nat outside
no ip mroute-cache
no fair-queue
interface Serial1
no ip address
shutdown
ip nat inside source list 102 interface Serial0 overload
ip nat inside source static tcp 192.168.1.21 8080 201.17.6.16 8080 extendable
ip nat inside source static tcp 192.168.1.199 65000 201.17.6.16 65000 extendable
ip nat inside source static tcp 192.168.1.21 65003 201.17.6.16 65003 extendable
ip classless
access-list 102 permit ip 192.168.1.0 0.0.0.255 any
line con 0
login
line aux 0
line vty 0 4
login
Jon Marshall Sun, 12/06/2009 - 15:22
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
[email protected]
interface Serial0
ip nat outside
no ip mroute-cache
no fair-queue
i1
Good catch on the access-list, sorry i was probably typing a bit fast
Also think the other issue is down to my typing as well -
can you change make the following change -
no ip route 0.0.0.0 0.0.0.0 189.57.241.77
ip route 0.0.0.0 0.0.0.0 189.57.241.177
Jon
Jon Marshall Sun, 12/06/2009 - 16:02
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
[email protected]
ok, after those 2 commands I can ping from the router after I unplug the cable modem, but not from the lan client
as soon as I plug the cable modem back in I can ping from the lan client again
so we are getting closer: I think we all we need is that ACL command again and we are set (hopefully!)
Not sure where we are with the config but what might be happening is you ping from the PC with the cable modem connected and it makes a NAT translation. Then you unplug it but the NAT translation is still there.
When you unplug the cable modem, before you ping again can you do this
router# clear ip nat translation *
Jon
I did better: unplugged the cable modem and rebooted the router while pinging constantly from a lan PC.
Curiously enough, it would alternate between a couple of "Reply from 192.168.1.1: Destination host unreachable" and some "Request timed out."
As soon as I plugged the cable modem back in the conextion was restored.
During that time with no cable modem (only the serial connection) however I could ping anything from the router.
(I also did your method with identical results)
Tha´s why I think it´s again the NAT-ACL issue, as it is the same that was happening with the cable modem connection in the first place.
